Are you there forums? It's me, Margaret.
I'm confused on how to achieve desired B+ voltages in my circuit. I haven't been able to find much literature on the subject either. Most resources describe how to design a stage with a given B+, but not how the designer dropped the B+ of a previous stage to the desired value. I know a resistor is used, but how to calculate that resistor value is eluding me. I am feeling like it's ohms law. Desired voltage / Anode current = R. Is it that simple? Is the hard part in working out the draw for your tube? Right now I'm working on figuring out a long-tail phase inverter that will be driving a pair of 6550s. My 6550s are at 480v. I have chosen to use a 12ay7 as my PI tube. So according to my data sheet, 12ay7 at 250v with a 47k anode resistor biased at -2.5v will draw approx 2.25 mA. Since this is the PI we then double this to see draw. 4.5mA. Now I need to choose a tail voltage? 60v is about 1/4 B+ so should provide enough swing to drive my output tubes. So my total B+ needed is then 310. So if I'm correct about ohms law being my guiding voice here- a 68k 2 watt resistor should supply me? With 310v at idle. Am I right? Does this all look sound? Thank you kindly for advice!
