I know not to run a signal into a tube amp with no load, and why there is a shorted switching speaker jack on Fender style amps, etc. But what about OTs with multiple secondaries? Say I wire up a 4/8/16 ohm OT to just the 4 and 8 ohm jacks, and put grounding switches on both jacks with the idea that I will only be using one side at a time. What do I do with the 16 ohm tap I don't plan on using? I'm plugged into the 4 ohm tap, the 8 ohm tap is grounded, and the 16 ohm is unused.
And what about PT's with unused windings, like say a bias tap when the amp is cathode bias? Or multiple HV secondary taps? Do we simply cut and tape them off?
