Follow on to frus and R.G's point on Class AB load line, I made the following graph to show what happens when you double the load, as bob and I mentioned above, it is not the "double plate voltage" (clearly wrong) that kills the tubes but rather the significant increase in screen grid dissipation at full output power. The operating conditions for the output stage is taken from the Ampeg SVT schematic found here. I rounded up the plate voltage to 700V, so it is easier to see. The output transformer has a Ra-a of 5k with 8 Ohm load and 10k with 16 Ohm on the secondary. Under normal operation with the 5k load, the screen dissipation is around 6W, well within the 8W limit; but the dissipation really shoots up to 22W with 10k load, can you say ka-boom!
Class A - solid, Class B - dotted. Per RDH4, Ig2 diss = Eg2 x (Ig2 max/4 + Ig2 idle/2).
