Maybe someone with a lot more knowledge than I can answer this for me. There are countless threads dealing with impedance matching etc., and various theories regarding the use of "the whole winding" of the OT. That being said.
Is there any science or math behind the concept of a different impedance - all else being equal - affecting the tone/output of the amp? I'll use an example. Lets assume a single amp used as a test subject. No changes. Now let's assume you have two identical speakers, save that one is 8 ohm and one is 3.2 ohm. Now lets assume you have two identical output transformers wound, each identical save the turns ratio is modified to reflect the required indentical impedance to the output section. Would you expect them to sound different, or the same, or ???
I guess what I'm asking is, speaker and OT differences aside, are there proven differences inherent to a low impedance load (3.2 ohm or 4 ohm) vs. a higher impedance load (8 ohm or 16 ohm)?
