Reading The Valve Wizard on amplifier design and have a question on looking at the very first diagram. What does the S shaped line refer to? It is not in any of the lists of electronic symbols that I have ever seen. I presume the two S shapes refer to other parts of the overall amp circuit. I hope I am not violating some use of the valve Wizard's material (which I really appreciate having access to as it is so damn good!0 - just want clarity.
what does this symbol mean?
Not only does it represent a sine wave, it tells you more. The relative size indicated the stage amplifies - so the plate signal has a larger amplitude. Note also the phase relationship, as the input signal goes more negative, the output goes more positive, so the stage inverts. If the circuit had been something like a cathode follower, the output phase would be the same as the input.
Oh, jazbo just said exactly that... never mind.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostNot only does it represent a sine wave, it tells you more. The relative size indicated the stage amplifies - so the plate signal has a larger amplitude. Note also the phase relationship, as the input signal goes more negative, the output goes more positive, so the stage inverts. If the circuit had been something like a cathode follower, the output phase would be the same as the input.
By the way this is really cool stuff!
