I know there is a long thread on this dating back to 2006 but I read several instances of what i believe are misunderstandings between the difference in a stereo effect and a stereo amplifier. This will be a bit of a long post, so grab a drink, smoke em if ya got em, i'll keep it as short as I can.
I want to build a tube stereo amplifier, but there are many complications and what ifs and all. So after long long time, I have what I think is the plan. Please let me know what your thoughts are as I am not really an electronics guy so far, but am learning. I have been a musician for over 40 years now so I do know a little bit. Okay, Here goes.
Misconceptions from another thread- Stereo effects are not really stereo.
Take for instance a chorus pedal. This effect takes an original signal, then makes a duplicate. this second signal is then processed for delay and detuning. both signals are modulated back and forth between two output paths. The physical outputs of the pedal are tip and sleeve such that the first signal is passed through one jack, and the second signal is passed through the second jack. at any instance in time you will see a completely different wave form between the two, so what you really have are two distinct signals being sent. The "rate" sets the speed at which the effect modulates. The depth sets how intensive the effect is.
A stereo delay has the ability to repeat a signal on each side at the same time, or change side to side in a "ping pong" way. It too, uses a tip and sleeve for its input and output.
A stereo amplifier uses two audio signals, one panned to the left, and one panned to the right. On car or home audio systems you have a balance and even a fade control to change the center point of the listening area. You can hear a bass guitar to one side and an acoustic guitar to the other. You could do this with a stereo guitar amplifier as well if you wanted. The important thing to understand is that if 2 speakers are right next to each other you might have stereo output, but you are hearing it in mono. The further the speakers are from each other, the better the stereo sound can be.
Following that line of thinking I believe the best coarse of action to building a true stereo guitar amp that can take advantage of "stereo" effects is this:
Build it modularly.
The simplest idea is to build a stand alone preamp circuit. "patch" in an effects loop that splits the signal into two separate outputs. Then build 2 power amplifiers to drive the speakers. The build should be made as a head, and the speakers should be cabinets that can be spread out.
In doing so, it is easy to see having 1 or more separate preamps so that you can have either a clean or dirty sound. By adding a second, you get the best of both worlds. I could see building a 3rd or even 4th preamp, modelling after Fender, Vox, Peavy etc..These preamps are controlled at the input jack of the amplifier. Just switch to whichever one you want at will. But there does need to be 2 separate power amps- 1 for left and one for right. The stereo splitting happens in the effects loop system which is actually more of a crossover circuit that "inserts" than a send/return loop. Now I realize we are talking about a lot of extra tubes and work here, but there are plenty of cheap solid state stereo amplifiers out there so...
In order for the effects loop to work properly, it needs 3 distinct paths. One path should go directly to to the left power amp. the second path should split between the left and right, and the third should be dedicated right. Here is where the "crossover" can work with the "Stereo" effects.
Because a stereo effect has an output A with a tip and sleeve, and the output B does as well, you cant actually connect using stereo (T-R-S-) cables. To do so may cause several issues including ground faults and imbalances due to different voltages being used in the effects chain. Therefor, use 2 pole jacks and cables. The "Crossover" part of this loop is to always keep a signal to both power amps. I would hate to turn off my chorus pedal and have only 1 side. The path that splits should be used for mono effects such as an analog delay or a reverb. The left and right should be used for devices having 2 outputs.
Another interesting thing here is that now in your loop design you find an opportunity to build in another module circuit to:
A) bypass the loop
B) incorporate in a potentiometer to control how much of the loop is in the mix
C) build in your left and right line outs for recording or to PA
D) turn several effects on and off at will while still maintaining the signal integrity.
Effects such as distortion and Wha's should happen between the instrument and the preamp so they are not accounted for, but could be used..
Each of the two power amps should have mono output- so that your left stays left and your right stays right. The preamp is all mono. The loop that splits actually sends a mono signal to each power amp, as do the left and right loops respectively. so, each power amp puts out a mono signal, and you can actually follow a single signal path from start to finish. But both sides can be modulated between the two, or "Panned" to one side or the other at any given time.
So again, it needs to be built as a head, without a speaker. There should be 2 speaker cabinets, spread out as far away from each other as they can be, and dont use stereo cables at all.
Mono Preamp out to effects chain, then out to left and right power amps, each driving their own speaker cab. I know you could buy the parts and hook it all together, but the effects chain wouldn't work right, and I hate multi effects units anyway. So I want to build this from scratch. Have the sound I want and not what Fender and Marshal think I want.
Okay- so what are your thoughts on this? I know the loop sounds complicated, but if you think about how a PA mixer handles individual and grouped signals, it becomes much easier to identify with.
Thanks for reading
Build it modularly.
A) bypass the loop
Thanks for reading
