I know in the push pull power amp with center tap output transformer, the plate voltage of each tube can swing much higher than the center tap voltage. For example, if the center tap is +400V, if the plate signal is 400V peak to peak. The plate voltage swing from +200V to +600V.
My question is about the single ended class A amp. Say if the idle voltage is +400V. If the plate has 400V peak to peak swing. Does it swing from +200V to +600V also? I believe it does, I just want to verify.
Thanks
Thanks
