On the typical blackface/silverface amp, how does the affect of the cap placed across the 3M3 reverb mixing resistor compare to the affect of a bright switch (or the very similar bright cap)? Are the approximate corner frequencies and slope similar?
Also, does the treble control on the tone stack cover a similar range?
The reason I ask is I have an older Allen Sweet Spot that does not have the cap across the reverb mixing resistor; I love the sound of the amp and my ears have grown accustomed to it - also, it's extremely pedal friendly. The amp does have a bright switch to give it more "sparkle" when needed, but I rarely use it. I also built an Allen Chihuahua which does have the cap across the reverb mixing resistor and I don't like the brightness of the amp when using fuzz, OD, or distortion. Now the obvious thing is to just remove the cap, but I've been thinking over the options.
- I could add a push-pull knob to switch the cap in/out.
- This lead me to thinking maybe a bright switch might overall have a very similar effect - which is possibly why David Allen removed the cap in the Sweet Spot (and several other of his amps) but added a bright switch.
- For ultimate flexibility, I could add a push-pull for the reverb mixing cap AND a push-pull for a bright switch - but in the end, they might sound near identical.
- Also, I found turning the treble control up a few numbers sounded just about the same, so maybe neither the reverb mix cap or the bright switch is necessary; instead, just turn up the treble when needed.
On a side note, what I find shocking are the amps that have both a bright cap and the reverb mix cap - like the vibrato channel on a Deluxe Reverb. Ugg, who wants that much treble boost?! Talk about "ice pick" to the ears.
I'm going to do some experimentation, but I thought I'd ask for feedback from anyone who might have already been down this road.
Thanks!
Mark
Thanks!
Mark
