Alan,
Both models are correct
- whether you view the AC equivalent circuit as:
a current generator with rp and RL in parallel across it
OR
a voltage generator with rp and RL in series
is purely a convenience thing. Both will give the same results.
If you are interested in voltages it is more convenient to work in the voltage domain and similarly if you are more interested in currents then work in the current domain.
This is like the old Norton (Current domain) or Thevenin (Voltage domain) analysis. Both are correct, just use the most convenient one for what you want to find out.
Cheers,
Ian
OR
Cheers,
Ian
