While I've seen lots of pictures and some builds questions remain. At the moment I'm putting together the power amp section- Fender AB763. In many regards I'm following the original PC board layout and it appears components, even on this high gain amp may be arranged without concern for proximity. That is: the resistors, capacitors and preamp tubes.
Here are the photos of the original and my current rebuild of the power amp driver:
![Click image for larger version
It does not appear that orientation or closeness of the traces on the PCB are a concern relating to feedback or oscillations. Is this correct? If so I assume that Layout problems are most affected by wiring and placement of inductors. I will add, there was a piece of copper clad PC board, grounded, placed over the first gain stages, presumably for shielding purposes.
Thank you for your considerations,
Silverfox.
Silverfox.
