I'll try to find a quick example here, but look for some amp with a single loop switch that selects either -10db or +4db. It switches both send and return at the same time, so it doesn;t matter when the loop is empty. In the -10db setting it drops the send to the lowr level and includes the boost at the return. FLip the switch to +4db and it leaves the send at high level and does not include the return boost. So it isn't a matter of turning down the send and not having enough return.
The schematics are hard to read, but I think the TSL100 has a switchable loop level. Note the switchable voltage divider in the send, and the switchable op amp gain in the return buffer. SW3 sections a and b. They switch together, so set one, you set the other.
