On an amp like mine, which no doubt everyone here is familiar with if not downright sick of hearing about,
is there a AC voltage range i should be looking at at the input of the pre PI master and then at the PI input depending on where the master is? I just want to verify that i don't have way too high a signal because my amp is insanely loud and it gets there by the time i would say the master is at 10:00. So whether at the points i mentioned or wherever, what should i look for?
On a side note, do you guys use the scope to arrange lead dress? I been chopsticking the amp while looking at the waveform and really noticing where certain wires should be move. The worse offender being the input. Good lord, move a power wire within about an inch of it and the waveform falls apart completely ! Makes me wonder if it would be a good idea to shrink wrap the 68k grid R and have shielding over it right up to just shy of the socket pin. Can't help but wonder if some sort of nastiness might be finding it's way to the input before the waveform even starts changing.
