So I'm working on this old Webcor amp right now. It's got 2 transformers between the output tubes and speaker.
The amp has a push-pull 6V6 output stage. I'm not totally sure if this is the right schematic, but I believe it is very close: http://i.imgur.com/Ob9NiZz.jpg
The amp as it sits on my bench right now appears to have 2 output transformers.
First I did some measurements on the transformer that's actually connected to the 8ohm speaker,
Here's what that first output transformer looks like:
With 6VAC applied to the bare leads on the right I measure:
168VAC between Yellow and Red on the left (turns ratio = 28:1)
168VAC between Green and Red on the left (turns ratio = 28:1)
336VAC between Yellow and Green on the left (turns ratio = 56:1)
The second transformer is a little puzzling to me..
It has 3 leads on one side, and 2 on the other.
It looks like this:
If I apply 6VAC to the white and blue leads on the right side, I measure the following on the left side:
Between White and Green = 119VAC (turns ratio = 19.8:1)
Between Yellow and Green = 119VAC (turns ratio = 19.8:1)
Between White and Yellow = 71VAC (turns ratio = 11.8:1)
I assume this second transformer was used somehow to get the impedance ratio more appropriate for the output stage driving the 8ohm speaker.
Can someone help me understand how I would implement these two transformers properly using the 6V6 output stage to drive an 8ohm load? Is this interstage transformer capable of accomplishing what I think it should be able to? This two transformer output section is confusing the heck out of me.. Any help would be greatly appreciated.
It looks like this:
