I have a homebrew amp that started as a Rt66 type of thing, but into el34's.
The amp is in a tweed super chassis & cabinet. 2x10" weber signature speakers.
After having microphonic/rattling issues with two different ef86's, I tried a 5879. This had less rattling, but didn't sound as good... The mid's and high's that made the ef86 special were gone. Additionally, after playing for a while, the rattling came back.
So... I disconnected the cathode bypass cap on the pentode, and put 1/2 of a 12au7 in front of it. There is a cap and a gain control between the triode and the pentode. This sounds good, but doesn't cure the microphonics on the pentode. I was thinking if the pentode wasn't the first tube, and if it's gain was reduced, then the noise floor would be high enough to not matter. Instead, even with the gain from the 12au7 up (or even with a 12ax7), the 5879 rattles like heck.
If you can ignore the rattle, it sounds pretty good though... On the other hand, I can't ignore the rattle.
I've tried O-rings on the pentode. I haven't tried shock mounting it yet, but it's only 6 inches or so from a speaker, so I'm not sure if that would help. (And even if it would help... Would I need to get a new pentode? Once these things start rattling, will they rattle no matter what you do?)
I guess I have a few options at this point:
1) drop the pentode, put a cascoded 12au7 in there instead. I don't know if the tone stack would have to change. (It's still the Rt66 type.) I also don't know that a 12au7 wouldn't be microphonic, but I wouldn't expect it to be.
2) weber now sells a shock mount adapter for 9 pin tubes. I could try that.
3) start over (again).
Any ideas?
Thanks.
Any ideas?
Thanks.
