I did a search...and there is some info...but I am still not sure.
Tube Diodes in general, but specifically the 6X5GT... says to use a 10 Mic cap at most.
I know we frequently run plate voltages over spec, but how critical is the max cap input spec.?
If I use a cap that is 22 Mic and the book says 10 Mic (that is double) how "bad" is that.?
Is it the Rectifier Tube that is at risk of Failing/Shorting...and then maybe exposing the rest of the amp to High Voltage AC.?
How close do You Guys adhere to the Max Cap Spec.?
Thank You
Thank You
