I'd appreciate your views on what you thought was the best way of going about the following little task:
Now and then I fix amps for people's jukeboxes. But this isn't about the amps.
A jukebox power supply has to run a small 28v motor (this psu just supplies the motor and some relays; the amp has its own psu). However these motors are old and the restorer would like me to get something in the range of 30 to 32v out of the power supply 'to encourage the motor along'. The power supply has a 20-0-20v power transformer running into a full-wave centre-tap (ie two-diode) rectifier. This with a 1000uF filter produces 28vDC. Like I said, the engineer would like a few volts more.
A bridge rectifier would give 40vDC of course, which would need dropping somehow.
The motor is on a 1A slo-blo fuse; the relays on another. Given the max current draw of 2A how would you go about getting the requested 30 to 32v?
By the way there is in the standard circuit a 500ohm 10W resistor from +28v to earth, across the filter. Not sure I know why...?
