I want to add a master volume to a princeton reverb clone in a way that makes the least change possible to layout. It would be nice if the pot had a switch so it could switch out of the circuit when not in use. I plan to put the pot on the back of the amp in the hole where the ground switch was traditionally located so as to avoid drilling new holes.
So the question is, what's the least disruptive way to do this? It hasn't been as easy as I hoped to find pots with various kinds of switches. I have a push pull DPST pot, and a pot with an SPST switch the closes when the pot is turned clockwise from the '0' setting (like a champ power switch pot). I haven't found any DPDT amp pots, although that would seem to be ideal. Anyhow, the weber schematic for the 6a14 (PR clone) uses a dual ganged 1M pot between the PI and power tube grids. This seems like the most obvious solution. I'm not sure I liked hearing distortion from the PI in this amp the last time I did it this way, although I can see that it's arguably part of the amp's sound.
Here's a picture of that from their schematic:
![Click image for larger version
The problem with that is that it adds a couple of big caps that are sort of inconvenient to have to crowd in (.1 orange drops), and I can't find a dual ganged pot with a switch.
So I'm thinking about a single pot w/ switch before the PI, configured in rheostat mode, so I can use a pot I already have with an SPST switch. Here's a diagram:
I like this because when it's switched out, the circuit it identical to the non-MV circuit, and I only have to add one smaller cap, and if it breaks the amp will still work, sans master volume. I guess the downsides would be that the taper will be different since it's not a voltage divider, and the tone will be differnt at low settings because it will mess with the impedance seen by the previous stages, right?
Any thoughts?
Anyone have a more elegant or minimal solution?
Any thoughts?
