PT question
  • PT question
    I've got a handful of PTs taken out of various devices (Hammond organ, couple of unknowns, etc.) and the lowest pre-rectifier B+ I'm getting is between 370v-440v depending on the PT. This is too hot to power EL84 tubes from what I've seen so short of purchasing a new PT what are my options to get the voltage down to a usable level? The one that gives me 370-0-370 is the perfect physical size for a project I'm working on and I really don't have the cash to get something else right now.
    --Jim
    He's like a new set of strings... he just needs to be stretched a bit.
    A big zener diode or a string of smaller ones on the CT will get the voltage down by the zener voltage. You can also add a sag resistor after the rectifier to drop more and simulate a rectifier tube. Or, if the PT has adequate 6V wind rating or a separate 5V winding you can use an actual rectifier tube instead.
      Bear in mind that the voltage output at full load will be less than when measured open circuit, around 90-95%.
      This is referred to as regulation.
      It tends to be higher for B+ windings intended for tube rectifiers as they require a minimum series resistance in their plate circuit (to limit current), which is generally designed in to the B+ winding, eg by the use of thinner wire.
      If using a tube rectifier, there should be scope to experiment with the different types in order to get a suitable dc VB+, eg a 5Y3 may be able to get it down to a suitable level.
      Pete
        PSUD will give you a pretty good idea of what to expect 'in circuit'
        Are the PTs centre-tapped and where are you measuring the voltage?
        A handy way of reducing B+ if you're using SS rectification is to use a choke and a very low value input cap - about 1uf - 2uf or so, then put the main filtering after the choke. I use motor caps for the input side.
          Short, crude answer: forget it, you're way too high for EL84.
          With 370+370VAC you are too high even for 6L6/EL34 if you use SS diode rectification, go figure (523 VDC).
          You are fine for big bottles using a tube rectifier or a *reasonable* series resistor to emulate it and add some sag.
          But forget EL84.
          Series diodes are a band aid, not open heart surgery.
          Sorry.
            Don't use any input cap with that choke. Make it a choke input filter, and that ought to make about 333vDC from your 370vAC.
              Right.
              Just that I doubt guitarzan has a suitable choke available and by own admission buying one is out of the question.
              The typical screen suply choke found everywhere is way too small as a main choke filter.
                Don't be sorry, that just means I can use this for something like a 6550/KT88 project later. I can handle disappointing news, I just try to find something good to take out of it. I have only begun salvaging parts from old equipment, I'll find the right size transformer for this yet. My next lowest one is only 200v-0-200v so that's too low. Plus it doesn't have a 5v winding.
                But forget EL84.
                Sorry.
                --Jim
                  The choke I have in it right now is out of a Fender Bassman 100 and the only other one I have at the moment is even bigger (physically) than that one. Chokes aren't that expensive, I can handle purchasing one of those. By the way, I should have taken that 20 henry rating off that schematic. It was on there from the original I copied the power section from. I don't know what rating this one actually is, all I know is it's from my Bassman 100.
                  Yes, I know... I should know the value of what I'm putting in my amp. (ashamed and hanging my head)
                  Yikes! It's a 90ma, 4 Henry choke. I guess 20 was a bit off, eh?
                  --Jim
                    Yes they are and I'm measuring from one lead to the center tap. Voltages across both "hot" leads are in the 740-880v range.
                    --Jim
