Which Pi filter is better?
The answer is - it depends on what you're using the voltages (and the current that comes out of each node) for. There's no good answer without knowing that.
It's a bit like asking whether an apple is better than a baseball. You need to know whether you intend to eat it, hit it with a bat, or play catch with it. One may be better, worse, or the same depending on the intended use.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by R.G. View PostThe answer is - it depends on what you're using the voltages (and the current that comes out of each node) for. There's no good answer without knowing that.
That's better, but now the question is more focused. What is eating current from B+? Single ended? Push-pull? Class A? Class AB? It does make a difference.
Class A needs all the "clean" it can get, push-pull tends to cancel ripple to some extent, more in Class A than Class AB.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Thank you. It's a single ended 6V6 amp, essentially a 5F2 with a 5F2A tone stack. The power transformer is 330-0-330. In the past I have prefered the tone that results from a plate voltage of between 350V and 375V in similar circuits. The amp will be used for recording, so it is important to minimize noise.
I agree with Dave. For single ended, B+ from the right side of the choke, screen from the node labeled "B+" and preamp from the right hand side.
That is, if all you have is the shown cap values. You can increase the cap value right after the choke almost without limit. Stick a 47/450 across that cap after the choke.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by Dave H View PostIf it's for the 5F2 I'd use the second circuit but have the B+ (OT connection) from the right side of the choke, the screen where B+ is and the preamp where the screen is.
(On further inspection the second schem I posted would have a 22k screen r., which seems stupid. Didn't really think this one through. <facepalm> )
