New member with some speaker related questions:
I got my first guitar amp in the '70s and have had a few over the years. A long time ago I learned that the power rating of the amp and the size of the cab and the number of speakers don't necessarily translate into actual volume output. I later found out what different speakers could do to change the character of an amp (or at least the amp-speaker system...). I've just accepted this as part of nature until I recently ventured into the universe of Tweed amps and would like to understand these things a little bit better
. So, I turn to you guys:
Some speaker models perform over the entire volume range, whereas others needs to be played fairly loud to open up and "breath". The latter sound stiff, chocked and dull at low volume, but can shine with the best of them when played loud. As far as I know, this characteristic is not revealed by specification parameters like sensitivity (dB) or power rating (watts) or magnet size/weight;
-What are the dependencies? suspension? -Is there a specification parameter that can be used to get a hint on how a speaker will perform over the entire volume range?
-Sensitivity is measured as dB at 1w and 1m. But what's the sound pressure level at 25w ?
A certain speaker might sound great with a particular amp, but not so good combined with another amp. A Speaker has an official frequency response curve, but the actual output frequency spectrum obviously depends on the amp and the instrument plugged into it. Let's say that the target is to get a flat frequency response; Then If I have a brittle amp, I could combine it with a speaker that emphasize bass reproduction and vice versa....
Problem is that since the frequency response of both speaker and amp varies with volume output, there's not much meaningful information to get from the speaker spec sheets to make an informed decision. Especially when entering the realms of distortion. You're on your own, trial and error...
-And what about a speaker's impedance curve? A speaker’s impedance isn’t just one number; its actual value will vary by frequency. Part of how hard a speaker is on an amplifier depends on the actual impedance curve;
-Is this also dependent on output volume? And is the actual speaker impedance in fact dependant on the particular amp, considering phase angle and damping etc?
Thanks
![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
Thanks
