Here is a fine link: The Philbrick Archive
Tube Version of OP Amp Circuit
So, you can turn a simple op-amp circuit into a complex tube design. The other way is to make a complex op-amp version of something that's fairly straightforward using tubes;
NE5532 power amplifier - diyAudio
I like that.
Originally posted by tedmich View Post...other things being made more complicated than they seem to need to be may include Phil Marchand's tube crossover...
Originally posted by tedmich View Postaudiophiles who insist on op amps
Originally posted by Mick Bailey View Post
Even for a science project, the results seemed so so... the SPL seems awefully low, and what is a reasonable class B amp? He must mean Class AB, not sure I want to listen to a class B audio amp... But he summed it up well with great understatement.
"I think it is more an experiment in building an unusual amplifier than an amplifier of ultimate fidelity."
Originally posted by Mick Bailey View PostSo, you can turn a simple op-amp circuit into a complex tube design. The other way is to make a complex op-amp version of something that's fairly straightforward using tubesThis isn't the future I signed up for.
Originally posted by Tom Phillips View PostSuch as 14 tubes with the pins soldered directly into the PC board. At least the user doesn't need to worry about dirty or corroded tube sockets.
Phil sells a discrete tube OP amp!
only $150 and its a dual OP!
he does use sockets too...Last edited by tedmich; 05-11-2014, 08:34 PM.
Originally posted by Xanthus View PostWhere can a person purchase this OP amp is there a URL?
See the links at the top of the page for pricing and order info.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
This also begs the question; does a more complex circuit really provide a better sound?
Some of the best tube amps are very simple but they yield very clear and concise sound quality. More complicated (more parts) newer tube circuits with transistors and ICs added to the tube circuits don't necessarily sound better to my ears.--Jim
He's like a new set of strings... he just needs to be stretched a bit.
Originally posted by gui_tarzan View PostThis also begs the question; does a more complex circuit really provide a better sound?
Originally posted by gui_tarzan View PostSome of the best tube amps are very simple but they yield very clear and concise sound quality. More complicated (more parts) newer tube circuits with transistors and ICs added to the tube circuits don't necessarily sound better to my ears.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
All Opamps used to be tube. They were used in many types of systems including fire control systems for artillery in WWII. Analog computers of the time used them extensively for arithmetic Operations, where their name came from.
Originally posted by km6xz View PostAll Opamps used to be tube. They were used in many types of systems including fire control systems for artillery in WWII. Analog computers of the time used them extensively for arithmetic Operations, where their name came from.
Greg
