Hi all,
This is probably more "guessing" than anything, and I have no immediate plans for this tranny; just curious for future reference. I got an old projector for peanuts and parts since it had tubes. I'm not saying any more about it, cuz I checked ebay AFTER I got it into pieces, and, D'oh! Check used prices BEFORE disassembly! Anyway I have a PT here.
Tubes powered:
ECC83 X2
EL84 X2
EF86 X2
ECL82 X1
EM84 X1
extra projector bulbs...
My question is, I've got 3 different 6V secondaries & a 12V. These are all unloaded measurements. The 6V ones break down like this:
#1 6.5VAC, 2ohm end to end
#2 6.7VAC, 0.6ohm " " "
#3 6.4VAC CT, 2ohm " " "
Is it safe for me to conclude that #2 is for the EL84s given the higher voltage (expecting more of a load & voltage drop) and the lower resistance (thicker wire, carries more current)?
I'd use #1 to power the EF86s or other small tubes, and #3 for ECC83s since it's got a CT.
I'm going to use less tubes than what it came with, won't chance a tube recto (even a 9-pin). The 12V I could use as a fixed bias supply for EL84s, no?
Meter used to measure is a Fluke 112, not lab quality, but certainly not cheap. I know that meters can be unreliable at very low resistances... But if this tranny burns up, I'm not exactly out anything for it. Just wondering if my "theory" is sound?
I know... next time draw the picture first! But this thing was packed so tight I couldn't follow anything. And the nice OT & Mullards were worth the price.
Thanks,
Justin
Tubes powered:
ECC83 X2
EL84 X2
EF86 X2
ECL82 X1
EM84 X1
Thanks,
Justin
