Identify circuit
Originally posted by Leo_Gnardo View PostThe "blue goo" is probably Permatex gasket sealer. Good stuff in an engine. Must be a good insulator or it would have gone up in a flash by now.--Jim
He's like a new set of strings... he just needs to be stretched a bit.
Originally posted by g-one View PostHow did you find the time? You must have been incredibly busy designing and building the space station, when you weren't putting together 22KW PA systems, when you weren't scuba diving all over the world, when you weren't designing, modifying and building incredible amps for all the greats, when you weren't putting silver wiring looms in the ships you probably built on your lunch break, all while you were actually repairing more amps than any of us have ever seen. Did I miss anything? Plenty I'm sure.
The Dos Equis "most interesting man in the world" sure doesn't have anything on you, does he."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Where is Carly Simon now that we need her?
"You're a legend in your own mind, a hero ... but not quite..."
"You're so vain, you probably think this song is about you."
Just the theme songs for a man out standing in his own fields.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by soundguruman View PostDanny Gatton, people called him "the greatest unknown guitar player."
But Jimmy Page bought me a beer! True fact.
And when Mick Jagger had his own band for a while @ 1988-9, the backup singers bought me lunch. Good folks! Terrific singers.Last edited by Leo_Gnardo; 05-18-2014, 09:05 PM.This isn't the future I signed up for.
Originally posted by gui_tarzan View PostI guess there must be some secret innovation under that P'tex, and probably a prototype since it's mounted on tongue & groove laminate flooring.The prince and the count always insist on tubes being healthy before they're broken
Originally posted by NateS View Post...a secret special sauce layering of tonewoods...
Formica (plastic) - Wikipedia, the free encyclopedia
Shocki etc.
Way up this thread you talked about maybe implementing a fixed/cathode bias switch to see what you preferred.
My experience:
I built a London Power Standard, in that I used a quad of 6V6 for the output, each output tube pair could be switched between cathode and fixed bias. I found that with the (common to the push pull pair) cathode bias resistor bypassed with a capacitor there was basically no difference in sound between fixed and cathode bias, with no bypass capacitor there was a difference. This is the way that Kevin O'Connor recommended it was built too (without the cathode bypass cap) and in subsequent email discussion with him he confirmed that he left off the bypass cap in order to get a difference in sound between cathode and fixed bias switch settings. He had also concluded that with a bypass cap there was little if any sonic difference between fixed and cathode bias.
These days I generally used a combination of the two (fixed and cathode bias) - I use a common to the output tube pair cathode bias resistor of approximately 25% of the normal value (no bypass cap) and then apply fixed bias to the grids to set the required idle current. The common, partial, cathode bias resistor applies some common mode local feedback and imparts some odd harmonic suppression via "harmonic equalizer" action but is particularly effective in suppressing intermodulation products with residual power supply ripple. This is something I learned from the Tube HiFi design I do. The effect is subtle but it eliminates some "muddiness" in the bottom end.
So you may want to give that a try.
Cheers,
Ian
Originally posted by Gingertube View Post...These days I generally used a combination of the two (fixed and cathode bias) - I use a common to the output tube pair cathode bias resistor of approximately 25% of the normal value (no bypass cap) and then apply fixed bias to the grids to set the required idle current.
I wonder if that amp has the proper cutouts to prevent the mains switch from rotating? Looks like if the nut came loose it could rotate and touch the chassis if not. There's a backup safety tie-wrap to rely on anyhow. For a newish amp not to have protection over exposed mains terminals (including the IEC inlet) isn't good practice.
Anyhow, looks like a straightforward design and about the same amount of work as a 5E3.
Itīs very simple, definitely not PPIMV and, personal opinion, wonīt offer too much grit, to say it politely.
No time to lift the entire schematic but from what I see, looks like a triode gain stage > volume ("Gain") > second triode stage > Fenderish tone controls > classic Fender volume control after it (here called Master) > standard PI > Power tubes.
Thereīs just one double triode available for the preamp so it canīt have much more than described.
Nothing new, shows some typical traits of many small, relatively unexperienced builders, (I wouldnīt call them "boutique" by any means):
1) canīt really design, so most they can do is to make a collage of blocks "borrowed" from other amps.
As in Mc D "new" hamburgers they offer every month: how many combinations can you turn out with so little "parts" available?
Ok , one month you skip the cheese and add *two* slices of bacon, next month you pull one and add extra lettuce .... in less than a year you are repeating yourself.
Same here.
2) to compensate for the lack of originality, they build the same old tired circuits (mind you, they may still sound very good ... ) but with "superior / expensive parts" ... so youīll find plenty of SoZo/Solen/whatever caps, Mercury Magnetics iron, NOS tubes, etc.
Plus killer Tweed, often very original (sometimes ridiculous) cabinet designs, etc. , sometimes beautiful polished wood cabinets, etc.
But inside ......
3) often beautiful internal wiring, of course turret construction , maybe silver wire, etc. ,,, coupled to gross mistakes such as that hot cathode bias resistor cooking *two* caps at the same time (now thatīs efficiency).
Or not fatal but minor mistakes such as non twisted filament wires (in fact run wide spaced one on each side of tube sockets to guarantee some vintage hum), gain and tone control grounding points straight to different pot cases instead of, say, a dedicated ground buswire with independent grounding, etc.
Go ahead, build your own, it will be at least as good, and probably better.Juan Manuel Fahey
