Originally posted by J M Fahey
View Post
Identify circuit
I'm not a fan of Samwha capacitors. Usually the lowest cost parts available for 22uF at 450V and parts marked 85C and 105C look the same except for the markings.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by jazbo8 View PostIf only it were true... here is the thread over at TAG.
FWIW I´m growing a 1 foot long, unkempt salt and pepper beard, which by itself should add $1000 to the value of any of my products
I do definitely *look* like a Guru.Juan Manuel Fahey
Originally posted by gui_tarzan View PostIf that's the case I should be able to come up with some "boutique" amps with a lot of attitude. They may not work right but they will scream bad-nasty!
I was just kidding, I know you were. That wiring is just insane and I get a kick out of boutique amp makers that charge a bazillion dollars for their super duper better than anything else creation. Come on, it's an RCA circuit (more or less) modified by a few people in the 1940s and it blossomed from there. Marshall's first amp was an almost direct clone of the Bassman.
I was at a music swap meet in Grand Rapids last winter and listened to a boutique amp maker explain to a guy why he should buy from him instead of Fender or Marshall or any of the other mega companies that are going to be around for a while. The amp builder had to be in his early 60s and I'm thinking, how much longer are you going to be able to build and warranty these? I'm not against the cottage industry whatsoever, I just thought it was interesting.--Jim
He's like a new set of strings... he just needs to be stretched a bit.
