mystery lead in Peavey amp?
  • mystery lead in Peavey amp?
    Whats up with this lead to nowhere in my XXX?
    its the center one a Red with yellow stripe
    it is even listed on the PCB?
    It's a center tapped winding off of the transformer, but it is not being used in that circuit.
    My take is that it is clean way of terminating the wire.
      Yep, and the same transformer wire harness can be used for other models which DO use the center tap.
