Aiken's improved back-biasing
  • Aiken's improved back-biasing
    Hey folks, I am beginning a spartan BF Fender style build with 2x 6L6, 12at7 pi, 12ax7 pre, etc. Single channel...
    The donor PT is 400-0-400, with no bias tap... I just stumbled upon Aiken's page on back-biasing, looks like a nice solution here as I'd like to shed ~50v B+ and make a -bias source..
    What is Back-Biasing?
    The circuits on this page are for tubes requiring less bias voltage i.e. EL84..
    Do you see any problem using a honkin stud mount zener to get around -50v for the 6L6?
    And lastly, does one of Aiken's circuits look more suitable for this situation?
    Just looking for the most elegant solution.. (other than springing for a new PT)
    Thanks!
    Originally posted by hylaphone View Post
    ...Do you see any problem using a honkin stud mount zener to get around -50v for the 6L6?
    And lastly, does one of Aiken's circuits look more suitable for this situation? Just looking for the most elegant solution.. (other than springing for a new PT)
    Thanks!
    The big stud mounted zener will work if it is attached to a spot that will allow sufficient heat dissipation. I.e not on a chassis location already hot from adjacent tubes.
    However, I think the best solution would be to use the zener for B+ reduction and then derive the bias from the B+ line as done in many Marshall amps. I say this because, as pointed out in the Aiken article, the bias will then track the B+ better as the line voltage varies. This also will allow you to independently set the final B+ and bias supply voltages to the optimum values. Keep in mind that you need to start with more than a -50 V bias supply to insure that you will have sufficient range adjustment for 6L6s at the output of your bias adjustment circuit.
    Cheers,
    Tom
      Sound advice Tom, thanks!
        This method of bias generation perfectly solves an issue i was having with to much B+. Except I have not been able to source any stud mounted ("big honkin") zeners with more than a 6.0V rating. Do you have a source for 10W plus zeners with 30 - 50V ratings?
          Zener Diodes | Mouser
            I use a Mosfet dropper rather than a high power Zener (or string of them) to reduce the B+. Easy to construct and suitable power Mosfets are inexpensive and commonplace. Then use a capacitor in a reactance-coupled bias supply if there's no bias winding.
              I've gotten parts from Mouser all the time. If you conduct a search from the exact link you gave Jazz you will find no results for power zeners above 6 volts. I like zeners and I suppose I could string 3 5 watt 12V zeners in series.
              I'm not real comfortable with MOSFET's but I understand Bipolars fairly well ... except I always get confused when trying to use PNP's for negative regulation and also getting the polarity correct between transistor and tube schematics.
              I was thinking of something like this circuit.
              What would a MOSFET circuit look like?
                Not quite. The simple method is a zener from gate-drain, and a resistor from gate-source.
                RG Keen did a write up:
                http://www.geofex.com/Article_Folder...osfetfolly.htm
                A high voltage one I've used:
                http://dalmura.com.au/projects/Selme...Schematic1.gif
                  Take a look at R.G.'s Mosfet Follies and scroll down to the B+ reducer;
                  Very similar to the BJT 'amplified Zener'.
