Short story... I wanted a tube reverb for my Trinity TC-15 kit I built. Didn't want to build a 6G15 just because I want to be different. Saw a nice simple design in Tonnes of Tone, saw the AX84.com FireFly by Doug H. So, I combined the two into my own design and built it. It sounds pretty good but I think it could be better. It has a 12AX7 (gain/isolation and recovery) and a 12AT7 driver (self-split design.)
I have a schematic for it as it sits today on my blog MakerDP
I did a lot of research on this and just the other day I discovered Hammond uses 12A_7 tubes in push-pull all over the place in their organ preamps and tone cabinets to drive percussion and reverb transformers. I have been studying those and they all use a Schmitt/LTPI to drive the push-pull tube. I am in the process of switching over from the self-split to this scheme to see how it turns out. Waiting on caps from AES so i should be able to do this fix on Tuesday or so.
Things I don't necessarily like about my design:
1) It has a grounding issue, which apparently is common for stand-alone reverbs. I have been reading all about that here and I think the solution is to build a transformer isolation box to sit between the reverb unit and the amp.
2) I have to push the dwell pretty hard to get a useable level of reverb, but it never really gets "boingy." I'll not regularly use a "boingy" setting but it would be nice to have just in case.
3) It is a little too "dark." I could use a little bit of a treble boost, or maybe somewhere in the circuit I am cutting too much out. The tone control has very little effect on the reverb.
4) I don't necessarily like the mix control. Specifically, how it really cuts the signal level when you dial-in the reverb. Will more gain at the recovery stage help with that so I don't have to turn the mix control quite so far to the "wet" side? How about just a standard "volume" control on the wet signal and then mix it back in with the un-attenuated dry signal?
Anyways, I'd like the pro's opinions here.
Thanks for looking!
Thanks for looking!
