I have a Super 60 head carcass that I want to build. I plan to make a AA964 Princeton except SS rectification, LTPI, and 6L6. I would like to then experiment with added features (tone stack, MV, PPIMV, extra gain stage, 6V6s, cathode bias, etc.) I have done a fair bit of work on my Princeton (with help from the forum, thank you) and am adequately skilled. I will make a schematic and layout drawing before I start.
What advice would you give someone starting their first build, mistakes to avoid, things you wish you knew when you started?
What are some simple mods I may want to try?
Any layout suggestions to leave room for expansion? I'm thinking I should skip a few turrets in between the different sections of the amp.
Thanks
Thanks
