Hi,
I have some theory blanks that I would need to fill so here's the situation. This is the Soldano Decatone FX loop:
![Click image for larger version
In order to get a line level the Send output level is decreased by the R37/R38 combo. From what I know the output impedance of the stage is R37 in parallel with R38 which is ~2k. My first question is: how much is the Return input impedance? Is it
a/ 470k
or
b/ 150k in parallel with 470k?
or
c/ something else?
Now if I want to set up a Send level pot like on the next pic and assuming the R40 (150k) resistor is not there the 2k2 pot will connect in parallel with R42 (470k) effectively making the stage impedance ~2k? Is that right? Then what would be the impedance if R40 (150k) is put in place?
If my assumption about the 2k input impedance is right what should be done to keep the Send level pot and have the Return stage impedance intact? Should I add a big capacitor in front of the R40 (150k) or ?
I would appreciate if anyone could explain those impedance issues for me.
a/ 470k
or
or
c/ something else?
