I have a similar in a maintenance thread already. But I would like to talk about this in general. Right now I have a blackface bassmann which has alot of hiss. It got a bit better when I changed the mixer resistors and the plate resistors.
But still there is quite a lot of hiss. Already when Vol is turned down. But of course it gets way louder when you turn it up. When just using the normal channel its OK. But if I add the Bass channel (which I voiced similar to the normal channel) there is even more hiss.
Other amps I have and had were Soldano, Badger 18, Marshall JMP. None of those had hiss problems. I also have a Deluxe Reverb which has hiss problems (just using the normal channel) but not as bad as the Bassman. Is there something in those Fender amps that generates this hiss? Is this something in the circuit and can anything be done to cure this?
I am not talking about hum in this case (!)
Thanks alot.
Thanks alot.
