If you look at this schematic
http://mhuss.com/18watt/schematics/1...perliteTMB.gif
After the first vol control you see two 470k resistors. The one that goes to ground takes away some of the signal. The result would be a weaker signal.
But what does the one that goes to the next stage do? Does it act as a grid stopper ? This would create quite a lot high end roll of I guess.
Another way is to see this is as a voltage divider just like a vol pot turned up half. The effects of changing the resistor values is explained here very nicely.
http://music-electronics-forum.com/t6412/
If you look at the 150k resistor in the Trainwreck build we don't have a voltage divider. But this still reduces the gain?
http://music-electronics-forum.com/a...ress-input.jpg
What is the sound difference between such a voltage divider arrangement and just having the resistor to ground?
Thanks for helping.
PS: I would like the change the title of the thread cause its not really acurate. But I don't know how
Thanks for helping.
