The Heater CT is for a "Ground Reference".
So I assume there is no current in the Filament Center Tap.....would it matter then, if you grounded the Heater CT with say.....the HT CT.?
Would that create a ground loop somehow...or be a source of noise.?
I guess what I am really asking is.....Does the Heater CT need to be isolated from any of the other PT Grounds/Center taps.?
Thank You
Thank You
