This is how I see it:
The problem is when you have open secondary, when the power tube cut off from conducting 100mA of current, the plate is going to swing up until the MOV or TVS turns on abruptly. Then it will dump the whole 100mA through the clamping device until the energy in the transformer is drained out. Even if you connect the clamping between CT to the plate, you expect to swing up +B above CT. So 450VX0.1=45W. Also, the lower the turn on impedance the clamping device, the longer it takes to drain the energy of the transformer.
Time constant is T=L/R, the lower the resistance of the clamping device, the longer it takes for the current to decay. This is the characteristic of inductor. I designed a high speed switching magnet, I used resistor as flyback load to increase R to shorten the decay time. But the voltage will swing very high. We had to use a bank of 50W carbon comp resistor to do that. Either way you use low or high impedance clamping device, you still have to dissipate all the stored energy.
I worked a lot with TVS voltage clamping in HV environment. You have to be careful in doing this as you can really burn something. If you just have one pulse event, it's ok. But if you have the user keep hitting the strings, it will heat up really fast and start burning.
Remember, it's not about what voltage it starts to conduct 1mA. It's the energy stored in the Transformer that needs to be Totally dumped off. At open secondary, the Transformer has very high inductance and whole lot of energy stored. Energy stored is 1/2 LI^2.
Using TVS was actually my first instinct. Then when I started calculating the power, then I realize that does not pan out.
