I have a PT with no heater center tap. I see where Fender used 2 100 ohm resistors. I have 2 10 ohm, 1 watt resistors available. Will that achieve the same effect as the 100s? Thanks.
What size resistor to use for an artificial filament winding tap?
Lower values will put an excessive load on the heater winding. Better to go higher than lower. I have seen 220 ohm in some Peaveys.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Calculate the power of a 10 ohm resistor with 3.2V across it. Hint: the resistors will be hot enough to cause serious burns.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
I'm with loudthud and g-one. You'll achieve the same effect with 10 ohms all right, and likely have a nice smoke machine besides.
Smallest value I've used 75 ohms. Largest I've seen used, 680 ohms but I busted those back to 150 because I was out of 100's. I'd say up to 220 or 270 is OK. Close enough for jazz. IOW it isn't critical, as long as you don't sizzle your resistors or transformer. Also nice to select your R's so that they're closely matched.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostI'm with loudthud and g-one. You'll achieve the same effect with 10 ohms all right, and likely have a nice smoke machine besides.
Smallest value I've used 75 ohms. Largest I've seen used, 680 ohms but I busted those back to 150 because I was out of 100's. I'd say up to 220 or 270 is OK. Close enough for jazz. IOW it isn't critical, as long as you don't sizzle your resistors or transformer. Also nice to select your R's so that they're closely matched.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
It is a steady 6 volts. The two resistors form a virtual center tap, 3v 100 ohms 100mw. 1/2 are fine, 1w are fine, anything larger is fine. there is no stress on them.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostIt is a steady 6 volts. The two resistors form a virtual center tap, 3v 100 ohms 100mw. 1/2 are fine, 1w are fine, anything larger is fine. there is no stress on them.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
"Also nice to select your R's so that they're closely matched."
Leo said that above. It's an important point. This is the disadvantage of a transformer with a filament CT, because the windings aren't always balanced and if they're unbalanced, they can introduce hum. If you have matched resistors (or a humdinger), you'll get better hum suppression.
Never forget, there are many sources of hum in an amp, and the real balanced point of a heater line may not be the best. Sometimes getting a little off center compensates for some other hum source and they cancel.Education is what you're left with after you have forgotten what you have learned.
... Also nice to select your R's so that they're closely matched.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by Pdavis68 View PostYou should measure them. Generally speaking you want them as close as possible."Take two placebos, works twice as well." Enzo
i would not go over 1/2 watt. in the rare instance that a tube shorts plate to heater, a 1/2 watt will act as a fuse and maybe save a transformer. i have probably opened up about ten amps with a cooked 100 ohm resistor or two,
matching is not important, in fact if you install a pot, you will notice that the setting that provides the lowest hum will sometimes be off center.
