Hi- Ive built 2 tube amps (and own 2 others) and satisfying to build and hear come alive etc, tube OD has still utterly eluded me & a mystery (not then say from the only time in my life Ive played an amp OD: turning a SF Champ up I had the pleasure of doing 28 years ago; added bewilderment being that it broke-up/ OD at 6 on that amp, & was more than Ive ever got cranking my 2 builds up).
1st build a 5E3: so bassy and loud I couldnt possibly turn it up, ever: the one time I did I was nr accosted by a neighbour. I did hear some 'medium' break-up but only for 2 minutes before I was shouted at & threatened (added mystery is it wasn't an appartment but at a BIG friend's house with 4 acres between it and neighbour/ it was so loud it hurt & I couldnt possibly have continued standing next to it even w'out harrasment for more than 10mins.. and Ive seen Dinosaur Jr live/ I know/ I can do loud).
So I sold off parts of that wasted build & built a 'Champ'. I added a tone control (humB's are too dark w'out tone at min 8 for me) ss rectified: so poss a 5F2-A of sorts then (I cant remeber exactly what it is!). Turning up didnt provoke neighbours but I get near to no OD even with a real SG, at dial 10. I did get some mild OD with a danelectro with its super hot pickups once (I guess the reason) but that's sold/ cheapo chinese gtr. It is going into a peavey blue marvel 8 ohm, 50w, 12" ext speaker cab, and not a std 6" or 8" tiddler.
(The other 2 amps: a wem 15w dominator- I cant turn this up even to see if I get break-up due to upsetting neighbours.. but I assume so from the youtube clips, maybe. Other a 40w Crate 6L6 2 channel beast.. I can get some mild break-up!! but marginally so and its only preamp OD I got by utter fluke/ modding ch1 by linking ch2's MV up to it to try and cure an amp noise issue).
Q: if I were to put it the 'Champ' into a 6" or 8" tiddler, instead of the (bog std) 12" 50w spkr.. would I expect to get more (even some at all in my case) OD at dial 10? or has the physical size of the spkr no bearing on the OD sound? If not, what is?
Break-up is a holy grail to me.. 10 years Ive spent trying now. My brain nr explodes when I read " it breaks up too early.." jeepers if only if only I could hear just some..
S.Chief.
S.Chief.
