I have a new build using a pair of EL84s. Using a 160 ohm shared cathode resistor I have 362 Vp but at 95% dissapation. Using a 180 ohm I get 370 VP at 91% dissapation. I could keep raising the resistor value but this is obviously going to keep raising the voltage too. I know it's a common trick to underbias Deluxe Reverbs to get an acceptable Vp, but does this same mentality apply to EL84s??? What if I tank the screen voltage???
Thats my concearns from a safety standpoint. Then there's the tonal considerations...
Will the tubes sound better at 360 volts biased hot or am I better off tonally at a higher voltage and lower current. And what affect does a high plate and lower screen have on the tone of EL84s???
Just hoping for some past experience input to help guide my next move.
Thanks
Chuck
Thanks
Chuck
