Hi I'm going to build a stereo guitar amp out of an old hammond (A-100 reverb amp I think) chassis and a GUlbransen organ tube power amp. Both amps have 2 EL84 output tubes with their own OTs
![Click image for larger version
I use a roland space echo RE-150 that allows me to separate dry and echo but I like to run some dry into my echo amp so I don't loose the big stereo sound when I turn off the echo.
I normally use my super and a small 2 channel amp but I have a single amp build in mind(with two single 12" cabs that fit together to carry)
The hammond has all the room and 3 12AX7 style sockets so I was thinking I'll build all the preamps there. would use 2 and run one through the Gulbransen amp for the echo and use the hammond amp for dry
Anywho
What I would like to know is can I make my preamp section 2 channels and then run a line from the dry channel pre phase splitter through a pot into the echo amp (pre phase splitter) so I can mix in some dry to the echo amp.
Would I need some sort of separating resistor and or an isolating transformer?
I have built a couple of little deluxes and a vibrolux , all succesfull as well as a bunch of pre conversions so I have some experience.
Anywho
