Yes, ESL is more important if the circuit can reach that frequency range as I posted the article in post #9. That's where the small cap can take over.
I really did not think much about this for guitar amps until this post. really the question is whether this is even important for tube circuit where the circuit is low current ( say no more than 400mA for 100W amp). Even the +B winding has quite a few ohms resistance. Say peak current of 400mA and ESR of 10 ohm, that's only 4V droop out of 400V. A few ohms or lower ESR in the reservoir cap is not going to affect a whole lot. The RC in preamp always have R in kohm range, the ESR is not going to affect the performance. For SS amp where you are talking about 10A of peak current and filter caps of 33,000uF range, ESR and ESL can sure become important and I can understand the reason of using parallel caps. Even ESR of 1ohm is 10V at peak current of 10A. If supply rail is only 60V, 10V droop is big deal!!!
Like Chuck said about people tried putting a resistor in series. People here should really try a resistor below 10 ohm in series with the filter caps is if the ESR increase to see how does that affect the sound. I don't worry about this, I don't use small caps in parallel and I use cheap caps. I am happy so far. Until something happens in the future, I am going to keep doing this way.
