To my simple mind, lowering the plate voltage in a typical PP tube amp will slightly improve the HF response as the lower volts =>lowered gains => reduced miller capacitance => reduced HF loss. Of course Rp goes up too and that reduces the HF. Net effect pretty much a wash. Checked with simulation.
Yet, I see it stated again and again that lower plate V=> reduced HF, most recently here 5R4 Rectifier Swapping | 5R4G/GB/GYB | kcanostubes.com that was mentioned in another (recent, not relevant) thread.
So,
Q1: Huh?
Q2: Why do I never seem to have a complete amp lying around to test?
Afterthought: I can see that if you lower the plate voltage on a PP output stage that the load line will cross the Vg=0 curve higher i.e. saturation and that will give you more higher order harmonics when cranked. This makes we wonder if people have been confusing harmonic content with frequency response.
So,
Q1: Huh?
