Hello everybody I'm kind of a beginner in electronics(made a few stompboxes).I bought this amp(fender PA 100) about 7 years ago and intended to work on it but sorta put it on the backburner.Anyway I have recently vowed to actually finish it now.I have looked at the amp and found out it would actually be a good amp to turn into a twin reverb.Here are a few things that the amp is similar to the twin reverb :
Power transformer
output transformer
choke
reverb transformer
all the valve tubes (4 6L6's and 1 =12ax7 2+12AT7 and 3 7025
All I basically have t do is put the right circuit board on there and the pots and I think that should be it(I thinK)
And now to my question.I want to save as much of the other capacitors as I can from the PA cause I dont want to spend too much if I dont have to.My question is that the filter caps on the PA are 2 caps of 100MFD 350Volts and 3 caps of 20MFD at 500Volts.On the otherhand the schematics for the AB763 twin reverb is 2 caps of 70 MFD at 350 volts and 3 caps of 20MFD at 525 volts.The question is can I use the existing caps on the PA in place of the AB763 values.Also how do I make sure that the caps are still good.Sorry about the long intro I just want to be thorough.any help would be appreciated
Power transformer
output transformer
choke
reverb transformer
