Going to do some experimenting with wiring 6L6's as a triode.Its a PP with 6L6GB's.I've seen schem where the plate and screen are tied together directly and also seen it with a 1k screen resistor between the plate and screen.I'm thinking the resistors would cause the volts on the screen to be a bit lower than the plate.Any thoughts would be welcome.
Opinions on 6L6 as triode
That's true, but the screen is closer to the cathode than the plate is. I suppose there would be some kind of 'sweet spot' where the voltage on the screen matches the local electric field (or in other words doesn't disturb the field). I have no idea what that voltage would be, however! But if we did hit a 'sweet spot' screen voltage, perhaps the number of electrons 'terminating' on the screen, relative to the number getting through to the plate, would be in proportion to their cross-sectional areas, which might help to balance the dissipation between the two. I'm sure this idea is not at all important in practice, but it's just interesting to ponder!
You do not want to exceed the screen voltage rating limit. (450 Vdc /6L6GC)
In older low power, low B+ voltage amps, this is not much of an issue.
If your B+ is around 450Vdc, you can go lower on that 1K.
I have seen 220 ohm screen resistors on 450 volt amps in triode mode.
As an aside: most players that I have run into that have a Triode/ Pentode switch, do not like the Triode mode.
It gets really 'dark'.
Which would be a benefit if you have an already 'too bright' amp.
This is an experimental platform I have.Its been thru a lot of various incarnations.Right now I have the plates down to about 385v's via a 50 something volt zener on the CT of the PT secondary.I actually have 470 ohm resistors on the screens.I have an adjustable cathode resistor on the power tubes so I tried it with the 6L6's then rebiased for a pair of 6V6's.Seems to be a more pronounced difference with the 6v6's.
Originally posted by Alan0354 View PostI never like the sound of triode mode. People like it in hifi amps, not guitar amp.This isn't the future I signed up for.
I think triode strapped is worth a try. Its just another amp sound. I've been experimenting with an EL84 se lately, but I've done pp's as well. I've been switching in a higher value cathode resistor and I'm also switching up to the 16 ohm tap to lower the load resistance. I don't know if that's necessary, but I'm having fun.
One of the things that happens when switching to triode is the screen follows the anode so while choice of screen resistor has an effect (I've switched that too) I think the anode will still follow even if you use a 1k instead of 100 ohm. I could be wrong about this. For EL84 I've tried everything from 100 to 2.2k.
Give it a go. You might like it. Yes it's darker, but you can emphasize the remaining high frequencies by turning down the bass. Besides, sometimes darker is cool.
Originally posted by g-one View PostLeo, when you do it in a Deluxe, do you do it with or without screen resistor?This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostScreen resistors IN place please, let's not beat those tubes up too badly. I stick with good ol' carbon comp 470R 1W - unless the user has a history of wrecking them, then I go for 5W wirewounds. Doesn't hurt to have tough 6V6's too, modern JJ seem to work fine, old RCA & Sylvania as well. Deluxes - I've even put in 6L6 - of course with bias set accordingly. Not a lot more power but they're not running near or beyond their ratings & tend to last a long long time.
I use a 150mA PT and OT of Vibrolux, these are good for at least 30W. So the limiting factor got to be the tube.
Originally posted by Alan0354 View PostI experimented with JJ 6V6S. I got lower power than two others I have. I did the power test on my amp, I never manage to get above 19W out of it. But just by changing to even the cheap Ruby tubes, I got 22W or more. I never understand why. I used resistor load, driving to clipping to measure the peak voltage. Everything else is exactly the same. The plate voltage is slightly over 400V. So I think I was comparing apple to apple.
I use a 150mA PT and OT of Vibrolux, these are good for at least 30W. So the limiting factor got to be the tube.This isn't the future I signed up for.
