An option is to use an auto transformer as an impedance converter. The Weber WZC100 is advertized as a 100W unit selling for $48.
https://taweber.powweb.com/store/wzc100.jpg
The specifications do not list the frequency response so we don't know how it will perform for bass but you could contact them and inquire.
You would mount the auto transformer in an accessory box, connect the amp output between the 0 and 8 Ohm leads and the 4 ohm speaker between the 0 and the 4 Ohm leads.
There are commercial solid state amps that have built in auto transformers to allow them to deliver rated power into a variety of impedance loads. The appropriate tap is selected as is done with a tube amp OT with multiple secondaries.
