I was thinking how to make 2 parallel loops in series the most simple way and came up with idea implementing Mesa DR style of Mix control. Although theoretically it should work I would appreciate if more people check it out for comments. The entire loop section will be in the sound chain at all times:
Provided the effects in use automatically provide unity gain (not so of all pedal type effects) and/or adjustable output all should be fine. Not the sort of thing for a commercial amp because low tech guitarists can confuse freking anything. But for personal use it should work the bomb! Having enough output from the first effect is paramount, but since you designed this you know that. It should work great."Take two placebos, works twice as well." Enzo
