How hot can a MOSFET safely get before becoming unreliable/failing? Most data sheet have a high end spec of 150C, but that's about the same temperature as a tube envelope.
I have a '50 watt' amp and and at half voltage reduction, which is the worst case from a dissipation point of view, the (TO-3P) case gets up to 100C pretty quickly, even on a large-ish heat sink in free air. These devices are now available in impressive voltage and current ratings, but you still have to dissipate the watts.
Has anyone done a reliable 50 watt or larger amp using PS/VVR? Maybe using a CPU chiller?
