I'm working on a reverb amp design and I'm wondering how much amplification to give to the reverb return signal before mixing it back in with the dry.
It seems like most reverb amps have a single 12ax7 amplification stage on the recovery side so they're getting something like 70x gain.
Accutronics says that one can expect a 1-5mV signal from the tank so a single gain stage will not be giving us more than about 350mV of wet signal.
On the dry side I'm expecting more like 5V after the first preamp stage so it looks like I will have a wet/dry signal difference of about -24dB.
So my question is, is that enough reverb? Is the -24dB wet signal big enough to make a difference or should I really be adding another gain stage to the recovery. With another gain stage I can get rough equality between wet and dry. Another option might be to cut the gain on the first preamp stage which would reduce the difference but wouldn't really bring the wet and dry into parity.
In my design I have one more high gain triode available that I can either use to boost the reverb or add crunch to the dry side. I expect I shall try both but I was hoping someone could offer an opinion based on experience. So far I'm just going on Spice data.
Hank
Hank
