For some reason I can't seem to work out how to hook up cliff type switching jacks.
I have two speaker out jacks with with normally closed switches that open when 1/4" connector is inserted. (Cliff type)
I want to wire them so that if no plugs are inserted the jacks short the output. If either plug is inserted the short opens. I can wire that. But I can not also make it so that both jacks get power if two plugs are inserted.
It seems like a very basic problem to solve. It also seems like there are enough switches to make it happen.
Yet... I can't seem to work out the connection scheme.
Is this possible? If so someone surely knows what the connection scheme is.
I can produce a drawing but It seems so basic as to not need one.
