A friend gave me a blue Matamp to look at. someone added a line out along the way and he doesn't know if it actually works. It works, but from looking at other schematics it seems the voltage divider off the OT secondary is a pretty high ratio, in this case 6.8K and 470K, 69-1.
Viewing schematics of other amps I'm seeing these types of dividers in ratios of about 10-1 to about 50-1. I'm not sure if I'm looking at it the wrong way but does this line out output seem low compared to the output into speaker load? Only about 230mV from the lineout when the amp is putting out full volume at clipping? Also why do the two waves look so different after clipping if they come from the same source?
This shows output into a 4 ohm load with the yellow trace, and line output on the blue trace. Below the waves you can see RMS output in the corresponding colors.
