I figure Enzo may know this being a fender repair tech and a hell of a tech period. The mustang III combo has your normal positive and negative wires going to the speaker's + and - terminals, but it also has a wire that goes to the speaker frame. Why is that wire necassary, what does it do? I have run mine to a external cab by hooking the + and - to a jack and using that to connect to the external speaker and not using that wire that goes to the frame. And it worked fine. Only did it to see how a EV sounded. Anyways, fender says that wire is necassary and this is a quote...
Can anyone tell me if this is some kind of misleading explanation for a reason they don't want you to know or what?
"The speakers installed in the Mustang Series combo amplifiers are
designed to be voiced specifically for each model. We recommend
replacing defective speakers with the exact same speaker, which may
be obtained from your Fender Dealer.
If a speaker is changed to a different type there are specifications to
keep in mind. The impedance (ohms) and power handling (wattage)
must match exactly between the original and replacement speakers.
In Mustang amplifiers there is also a third wire that is attached to the
frame of the speaker that must be attached to the frame of the
replacement as well – if this is not done properly, the performance
of the power amp may be affected.
There are speakers on the market that have the negative terminal
common with the frame of the speaker – these speakers CANNOT
be used in a Mustang amplifier, as this will result in damage to the
power amp.
Any deviance from stated specifications or improper
installation of the speaker (especially pertaining to the
attachment and proper grounding of the third speaker wire)
will void the amplifier’s warranty."
power amp.
