So my, fairly small, knowledge of filaments and wattage are telling me I can convert a typical 6.3vac heater supply to 6vdc just fine WITHOUT changing the PT. I'm toying with this for a tube mic preamp design to reap the benefits of reduced hum injection. Gonna use a full wave bridge. Only real issue I forsee is the need for either a series resistor, series diodes, or high power zener. I'm thinking resistor or diodes to avoid extra loading on the PT from a zener. I dont believe this changes the wattage required of the PT filament winding....as it's supplying the same wattage DC or AC. I also am doing this so I can use a PT I already have. (no 5v rectifier winding) I know a 5v winding would actually work perfectly without series diodes as in the following math. I will use a full wave bridge with a 4700uf capacitive input. (more than 2,000uf per amp)
2 12ax7 = 600ma
1 6v6 =900ma
Total = 1.5A
my math
Secondary voltage 6.3vac
Target DC Voltage 6.3vdc
6.3rms=8.9vPEAK=rectified dc voltage
Accounting for diode drops (.7v) 8.2vdc
If i add 3 series silicone diodes I should be at 8.2-2.1 = ~6.1vdc.
I'm probably missing something....what is it?
2 12ax7 = 600ma
1 6v6 =900ma
Total = 1.5A
my math
