I did a resurrection job on an old amp - triode strapped 6J7, to pentode mode 6J7 to single ended 6V6, 80 rectifier - see schematic below.
It was drop dead gorgeous and i want to build a clone.
My question is how much of the lovely compression of that amp might be attributable to the 10" field coil speaker.
I have collected 5 identical field coil speakers (Rola K) and one 12" field coil speaker. I also have a Jensen 10".
Should I "design in" the field coil speaker or just go with the Jensen?
Thanks,
Ian
Edit: A better copy of the schematic is here:
http://www.diyaudio.com/forums/instr...amplifier.html
Thanks,
Ian
